Hi David,
Without changing the KMotionCNC GUI how about this:
Add an M Code at the end of all your programs to run a program in KFLOP to increment a count and to display a message box with the count. ie. "XXX parts completed"
Add a User button to run a program in KFLOP to reset the count to zero.
Message: 11808 |
Date: 6/28/2015 |
Subject: Re: Simple Parts Counter |
Thanks Paul. That sounds reasonable and doable.
Best regards,
David.
On 6/27/2015 2:36 PM,
paul@... [DynoMotion] wrote:
You could create two global integers, desired_part_count
initialized at -1, and current_part_count initialized at
0, when a new gcode file is loaded. When
desired_part_count is -1 nothing happens. If you want to
set a desired part count, use a button or menu item to set
desired_part_count. At the end of each gcode run you can
check desired_part_count. If it's a positive value then
increment current_part_count and compare with
desired_part_count. If it is equal, then do a message box
saying so.
Message: 11809 |
Date: 6/28/2015 |
I tie these into the circuit that triggers the start sequence from my pendant to count cycles.
So separate from the gui. And also alows you to start the sequence with out a count manually with the gui rather then the pendant button if you need to fix something
eBay item number 331580637701
B
Best regards,
David.
saying so.
Message: 11815 |
Date: 6/28/2015 |
Thanks for your suggestion. It seems simple enough that even I could
make it work.
What would be your suggested code to display a message box?
Thanks again,
David.
On 6/27/2015 2:38 PM, Tom Kerekes
tk@... [DynoMotion] wrote:
Hi David,
Add a User
zero.
Message: 11816 |
Date: 6/28/2015 |
Thanks Bill,
That looks like an interesting readout. I'll have to take a good
look at it.
Best regards,
David.
On 6/28/2015 9:24 AM, Wcarrothers Yahoo
B
Best regards,
David.
On 6/27/2015 2:36 PM, paul@...
desired_part_count initialized at -1, and
current_part_count initialized at 0, when a new
gcode file is loaded. When desired_part_count is
-1 nothing happens. If you want to set a
set desired_part_count. At the end of each gcode
run you can check desired_part_count. If it's a
positive value then increment current_part_count
and compare with desired_part_count. If it is
equal, then do a message box saying so.
Message: 11817 |
Date: 6/28/2015 |
Hi David,
That would be the MessageBox.c example.
The example shows a fixed message to display "Hello World". To create a string (array of characters) to show the count (ie persist variable 25) you can use the sprintf function to "print" to the string instead of the Console. Something like:
persist.UserData[25]++; // increment the count char MyMessage[80]; // String to be created and displayed sprintf(MyMessage,"Run Count = %d",persist.UserData[25]); // build the message we want to show MsgBox(MyMessage,MB_OK); // Show it
HTH Regards TK
Message: 11821 |
Date: 6/29/2015 |
Thank you very much for your help! It is much appreciated.
With best regards,
David.
On 6/28/2015 7:23 PM, Tom Kerekes
Hi David,
That would be
The
displayed
to show
